TwinTurbo.NET: Nissan 300ZX forum - Good Question! (more)
Subject Good Question! (more)
Posted by Tom B(WI) on April 03, 1998 at 8:00 AM
  This message has been viewed 4 times.
In Reply To Whats better on N/A? H or X pipes? posted by Arthur on April 03, 1998 at 02:34 AM
Message : Does it really matter which? And if so, what makes one better then the other?
I saw an article from July, 1997 discussing the X pipe versus H pipe on a Rustang (the
engineers at Bazzani Exhaust have developed one for that car). The article was a bit
vabue, so I called the engineers and talked to them about it.
Theoretically, the X pipe allows exhaust gas to go to the pipe with the least resistanc
at the time it travels down from the engine. This means less backpressure, and that will
give you a bit more HP and some bottom end grunt. The Rustang article 'thought' they could
see about 10 hp at the wheels. It must work if NASCAR teams are using this approach, which
is what the Bazzani engineer told me.....
The H pipe equalizes pressure - that's all. It doesn't scavenge any power like the X pipe
does. An H pipe is better than equalizer tubes because it also has a resonator function to
make the exhaust a bit quieter. X pipes don't, although at least one design puts resonators
on both of the exhaust tubes after the X.
When I rebuild my exhaust, I'll change the resonator out for a home made X pipe and see...
Hope this helps!
